AC question
You can pull parts from a Cherokee out of JY for pennies practically. I'd fix it, you don't need an A/C shop to do this for you. You can get an A/C system operational on the cheap if your MJ came with it. The A/C may spin freely when the engine isn't running but does it lock up when running and you turn the A/C on? If not, it could be a wiring or fuse issue. If it runs but isn't cooling, try adding a can of freon with the IR leak detector, you'll be able to see where the leaks are under a black light.
