flint54 Posted August 26, 2011 Share Posted August 26, 2011 First, the data: 4.0L - 4wd - D30 front - AX15 - 231 - 2" lift Next the change: was 92 high pinion, now 01 low pinion was original LCA/UCA, now ZJ LCA/UCA (lengths virtually identical) My old front DS was in poor shape, so it went to the scrap yard. I grabbed a JY DS in great shape, paying attention only that it came from the newest 4.0 XJ I could find. Stripped, blasted, coated, new U joints. A work of art. It will not fit. Fully collapsed I cannot get it in, and, without further ability to compress wouldn't want it in there now anyways. It measures 30.7 center to center fully collapsed. I've now learned that auto shafts are longer than manual. Here's my question: I will have it shortened to what length?? How much remaining extension with shaft installed is appropriate? Link to comment Share on other sites More sharing options...
xjrev10 Posted August 26, 2011 Share Posted August 26, 2011 I paid about 180 bucks for a BRAND new, ready to bolt in from my local driveline shop. If I remember correctly they wanted the distance from weld to weld. Weld to weld as in where the double cardon and yolk are welded on. Link to comment Share on other sites More sharing options...
veritas4156 Posted August 27, 2011 Share Posted August 27, 2011 Just had a near rear shaft made and they wanted the length from the center of the u joint cap to the center of the u joint cap because apparently some ends are different lengths from different manufacturers. Tom Woods wants all sorts of crazy measurements, on their site they have a 5 page guide to measure your shaft properly (that's what she said?). Shows their quality work. Other places just asked me for weld to weld length. Link to comment Share on other sites More sharing options...
flint54 Posted August 27, 2011 Author Share Posted August 27, 2011 I am hoping someone here might tell how much to cut off, or, how much remaining extension I should have with the shaft installed. Thanks! Link to comment Share on other sites More sharing options...
flint54 Posted August 27, 2011 Author Share Posted August 27, 2011 A little more digging and I think I found it here: http://www.myjeepxj.com/useful-informat ... infomation Roughly 1.4 inches difference in length. Link to comment Share on other sites More sharing options...
