Knuckle/Hub Differences
Surprise, surprise, the axle swap is not quite as "plug and play" as I had
assumed. Was puzzled why the rotors would not fit, until I measured the
distance from hub face to knuckle face. On the 1992 D30 that distance
is 3.25". On the 2001 D30 that distance is 3.00". Gotta go buy new
rotors to replace my perfectly good rotors. Rats!
Older and newer rotors have a difference in the thickness of the mounting surface. That difference is made up by the older/newer unit bearings, not the knuckles.
So either get a new pair of rotors, or get another pair of unit bearings. Rotors are cheaper. However, your old rotors should work just fine with your old unit bearings.
