maddzz1 Posted September 8, 2011 Share Posted September 8, 2011 It could also be the lower rad hose collapsing . Did you swap the spring from the old one when you put the new one in? Or the gauge might just be bad, mine reads around 155* all the time. Link to comment Share on other sites More sharing options...
Thunderbear Posted September 8, 2011 Author Share Posted September 8, 2011 It could also be the lower rad hose collapsing . Did you swap the spring from the old one when you put the new one in? Or the gauge might just be bad, mine reads around 155* all the time. I'd give anything for it to be that instead of the head gasket. :ack: Lower hose still has the spring in it. That must be disconcerting, you don't have a 165 thermostat in it, do you? Link to comment Share on other sites More sharing options...
