jimoshel Posted August 10, 2011 Share Posted August 10, 2011 I'm replacing the brake pads on the GF '06 Dodge 1500. Not sure, Should I go with semi-metallic or ceramic? Not worried about price, just reliability and performance. Inquiring minds want to know. Link to comment Share on other sites More sharing options...
SubSonic Posted August 10, 2011 Share Posted August 10, 2011 I'm replacing the brake pads on the GF '06 Dodge 1500. Not sure, Should I go with semi-metallic or ceramic? Not worried about price, just reliability and performance. Inquiring minds want to know. The more metallic, the longer the pads last, but the quicker they wear the discs. There is usually a middle of the road pad (semi met.) that does a decent job at longevity, but doesn't wear the discs too quickly. Edit: Did a bit more research and it so happens that I got it a bit wrong. Ceramic pads may actually last longer, but should only be used with rotors designed to be used with said pads. They are *supposed* to be quieter... and produce a less obnoxious dust. Meh... Link to comment Share on other sites More sharing options...
88pioneer Posted August 10, 2011 Share Posted August 10, 2011 Anytime I've used ceramic they squeal like a mother, I usually use semi metallics. Link to comment Share on other sites More sharing options...
