mechaincal coolant gauge
Has anyone installed a mechanical temp gauge in a 4.0? the port in the head is too small as well as the drain in the block. I picked up an HO thermostat housing planning to use that port as its the correct size but the the hole is too shollow for the sensor.
Thanks,
