the only issue you'll have is ya won't be able to turn the key all the way back without manually pushing a rod on the underside of the column. I have a auto column in my 5 spd
Wired mine up, no problems.
Then your missin that rod that has a cable that is supose to attach to the automatic shifter. It prevents you from turning the key all the way back without the trans being in park.
