Blue88Comanche Posted July 28, 2011 Posted July 28, 2011 will a XJ transmission mount cross-member fit a MJ? I have a very dead BA10/5 and want an AX15.. I found a 1990 AX15 in a local JY for a XJ..
Geonovast Posted July 28, 2011 Posted July 28, 2011 There are no differences between XJ and MJ crossmembers. The BA 10/5 and AX-15 do use different crossmembers, however.
Blue88Comanche Posted July 28, 2011 Author Posted July 28, 2011 so the XJ AX15 crossmember should bolt up to the MJ (1988 BA10/5) with out too many problems thanks
Boots Posted July 28, 2011 Posted July 28, 2011 When I did the NV3550 swap, the Cherokee cross member didn't have the holes for the brackets that go on the inside of the frame rails above the cross member. I don't think that all of the Comanches came with those though, but it's not a big deal to drill four holes.
