Where are all of the grounds at that might be the problem to my not having gauge lights because I changed my light switch and it didn't work
The dash ground is behind the kick panel, drivers side. Check the fuse first. Make sure the HL sw is rotated max clock wise. It might be in the dim, CCW position.
