wallisek Posted July 12, 2011 Share Posted July 12, 2011 Even after replacing my bad CPS, I still can't get the engine to start. After a few seconds it briefly catches for a brief split second, then nothing. Has good fuel psi, spark, coil is good, new cap, rotor, wires, new injectors, etc... Ran a compression test which was less than encouraging. 1) 132 psi 2) 120 psi 3) 142 psi 4) 150 psi I know I quadruple checked my timing chain when I put it on, and I pulled the valve cover tonight and watched both valves close at TDC. Distributor is properly indexed and pointing to #1 terminal at TDC. Is it possible I screwed up the timing chain? Any ideas because I'm completely out.....:wall: Link to comment Share on other sites More sharing options...
JeffN Posted July 12, 2011 Share Posted July 12, 2011 your distributor could be 180 degrees out there is a compression tdc and an exhaust tdc on the valves Link to comment Share on other sites More sharing options...
wallisek Posted July 12, 2011 Author Share Posted July 12, 2011 Dizzy is good. At zero degrees tdc, compression stroke, both valves closed. Link to comment Share on other sites More sharing options...
wallisek Posted July 13, 2011 Author Share Posted July 13, 2011 I did some reading and supposedly I shouldn't worry too much about the compression being a bit low since the rings haven't been broken in. Makes sense to me anyways. Is it possible the cam sensor / pickup coil in the distributor is bad? Link to comment Share on other sites More sharing options...
JeffN Posted July 13, 2011 Share Posted July 13, 2011 if the pick up coil in the distributor is bad you would have no spark. Have you checked to see if your injectors are getting a pulse? You would need a noid light to check them Link to comment Share on other sites More sharing options...
partsmj Posted July 13, 2011 Share Posted July 13, 2011 timing is tricky the rotor goes just before no 1. here is a couple of links. http://www.jeepforum.com/forum/f12/timing-4-0l-508405/ http://www.askamechanic.info/askamech2/ ... iew/48/47/ Link to comment Share on other sites More sharing options...
wallisek Posted July 14, 2011 Author Share Posted July 14, 2011 I only had enough time last night to test wiring. Going to test injectors today but I'm pretty sure they are firing. Plugs smelled of gas when I pulled them. For the 2.5L my FSM says the rotor is slightly past the 3'oclock position at TDC. In this configuration, my rotor is lined up directly to the #1 terminal. partsmj, you say it goes slightly before #1 (3'oclock) Chilton says 6'oclock position. :huh???: FSM says 3:30'ish. :wall: Link to comment Share on other sites More sharing options...
wallisek Posted July 17, 2011 Author Share Posted July 17, 2011 Took the timing cover off today, verified cam was properly set. Put the oil slinger on while I was in there, looks like I forgot to install it the first time. :shake: Set the distributor for just past 3'oclock and it still wouldn't start. Took distributor apart and noticed the inside of the rotor mount (the part the passes the pickup sensor) was really rusty. Took a wire wheel to it, re-installed and SUCCESS! Link to comment Share on other sites More sharing options...
