Simple AC Question
Correct, you do need pressure in the system for it to turn on, but if its not cooling, it may not be enough pressure to operate properly. I had a full size Dodge doing that today, the compressor came on and off fairly normally, but it wouldnt cool, only had less than half of the amount of refrigerant that it should have had. So you need to check that as well.
