jpdriver1 Posted July 5, 2011 Share Posted July 5, 2011 picked this up over the weekend -- the po did not know exactly what it was indented to do --- and yes it was free -- anyone have any experience with them Link to comment Share on other sites More sharing options...
Automan2164 Posted July 5, 2011 Share Posted July 5, 2011 Isn't that just for high altitudes? Rob Link to comment Share on other sites More sharing options...
jpdriver1 Posted July 5, 2011 Author Share Posted July 5, 2011 thanks Rob -- that's possible --- anyone else? Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 6, 2011 Share Posted July 6, 2011 Since there's a wire on it, one only?, it probably acts like an adjustable MAP sensor, i.e. varies the output voltage to the ECU depending on the MAP vacuum generated from the intake manifold. It's most likely set up to lean out the A/F mixture slightly and provide better fuel economy. But I would not use it unless I had an A/F meter hooked up to monitor the mixture across the RPM range. Link to comment Share on other sites More sharing options...
jpdriver1 Posted July 6, 2011 Author Share Posted July 6, 2011 thanks Don -- good idea -- I'm gonna try to get over to the jeep speed shop near here and ask them too Link to comment Share on other sites More sharing options...
jpdriver1 Posted July 8, 2011 Author Share Posted July 8, 2011 hornbrod is the winner --- according to T&J performance -- it is an adjustable map sensor -- the wire is for connecting to a 12v switched source --- most likely made by turbo city -- per turbo city it should work with renix and high output engines both :cheers: Link to comment Share on other sites More sharing options...
deziped Posted July 9, 2011 Share Posted July 9, 2011 If your using hydrogen to supplement your gas fuel you need an adjustable device for the MAF to tell the EC to lean the gas input from the injectors. But Ive never seen one that large or configuration. Probaly not related. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 9, 2011 Share Posted July 9, 2011 If your using hydrogen to supplement your gas fuel you need an adjustable device for the MAF to tell the EC to lean the gas input from the injectors. But Ive never seen one that large or configuration. Probaly not related. You are correct, not related. :cheers: Link to comment Share on other sites More sharing options...
