Rattle under the drivers side floor board
Hi,
I Have a 1989 MJ 2wd I6 and recently a thumping and rattling started that I can feel through the floor boards on the drivers side. I thought it may be a bad suspension bushing or possibly a motor or transmission mount but can't find anything visually wrong when I go underneath the truck. It seems to be louder after hitting bumps or turning.
Any ideas would greatly be appreciated.
Thanks
check the rear end if theres a lot of slack in the rear end it could be going out and the vibration travels up the drive shaft and well that where you sit. it will almost sound like a wheel bearing. hope its not but be sure to check to be sure.
