hick92 Posted June 27, 2011 Share Posted June 27, 2011 wats the torque specs. for the head of a 91 4.0 Link to comment Share on other sites More sharing options...
jimoshel Posted June 27, 2011 Share Posted June 27, 2011 first step=22 ft lbs second step=45 ft lbs third step;bolt no 11=100 ft lbs, all others=110 ft lbs. Bolt 11 is the front left corner. Coat the threads of bolt 11 with a sealer, Loctite 592 or equivalent Link to comment Share on other sites More sharing options...
hick92 Posted June 27, 2011 Author Share Posted June 27, 2011 now can i get help with the procedure Link to comment Share on other sites More sharing options...
jimoshel Posted June 27, 2011 Share Posted June 27, 2011 Clean all threads with a wire brush. Bolts and holes in the block. Start with number 1 bolt. That is the middle bolt, right hand side. Left, right is determined as you're sitting in the drivers seat. After no 1 is no 2, straight across the block and on the left hand side. Continue in a clockwise fashion until all bolts are tightened to specs. your starting in the the middle and working your way out. After the last time around at final specs go around again checking that all bolts are tight. Sometimes it takes 2-3 go arounds to get it. Link to comment Share on other sites More sharing options...
jimoshel Posted June 27, 2011 Share Posted June 27, 2011 Bolts can only be used twice. After you've replaced all the bolts put a white paint mark on the head of the bolt. If there is a bolt with a white paint mark on it when you removed them, discard it and get a new one. Link to comment Share on other sites More sharing options...
hick92 Posted June 27, 2011 Author Share Posted June 27, 2011 ok i was just goin to buy new bolts Link to comment Share on other sites More sharing options...
