87manche Posted December 18, 2005 Share Posted December 18, 2005 SO I took off my trim piece to fix the blower motor and it escalated into a full scale dash party tonight. Got the blower motor fixed, works better than when I bought the truck. Cleaned all of my guages, cleaned the inside of the cluster. All that dust just bugged the hell out of me. Replaced some burnt out dash lights. Couldn't find the one for the HVAC controls, did an 87 have that? Cleaned my entire fuse block, replaced every fuse. Brake fluid was mean to some of the older ones. So, now I've got killer heat, the lights are brighter, and I pumped everything full of di-electric grease, so it should be good or a while. I even mounted my Siruis receiver to the dash, after I "customized" the mount for it. How did you treat your Jeep tonight? Link to comment Share on other sites More sharing options...
bumpy Posted December 18, 2005 Share Posted December 18, 2005 How did you treat your Jeep tonight? i got bored and ran into it with my yj cause the heat isnt working :evil: you sound ambitous... wanna come fix mine? :D Link to comment Share on other sites More sharing options...
87manche Posted December 18, 2005 Author Share Posted December 18, 2005 not ambitious, friggin cold. I haven't had a blower motor al week. I was just relying on going fast enough to provide heat. About 20 minutes of driving would make it so you could take your gloves off :) Link to comment Share on other sites More sharing options...
moparmanche Posted December 18, 2005 Share Posted December 18, 2005 My Jeep is sitting in the garage with no motor :cry: Waiting for my friend at the jy to locate a 3.4 camaro motor. Its too cold to work out there any way. Only 5 degrees and no insulation or heat in the garage. Link to comment Share on other sites More sharing options...
pingpong Posted December 18, 2005 Share Posted December 18, 2005 One of my MJ's is 2 hours away getting an EXO cage built, the other one, I am still trying to figure out whats wrong with it. Mostly drank beer and ate steak while trouble shooting the problem. Patrick Link to comment Share on other sites More sharing options...
87manche Posted December 18, 2005 Author Share Posted December 18, 2005 One of my MJ's is 2 hours away getting an EXO cage built, the other one, I am still trying to figure out whats wrong with it. Mostly drank beer and ate steak while trouble shooting the problem. Patrick sounds productive :D Link to comment Share on other sites More sharing options...
pingpong Posted December 18, 2005 Share Posted December 18, 2005 We figured out that its is not compresion, or a plugged catalytic, then we figured out my trash can in the garage only holds about 45 empty beers. plus various oil fluid cans. Patrick Link to comment Share on other sites More sharing options...
87manche Posted December 19, 2005 Author Share Posted December 19, 2005 what's it doing. From the sounds of what our checking I'm guessing it just runs like poo. I've still got an odd high RPM WOT issue. I'm pretty sure it's something with the injectors. I'm pretty sure one of them is shorting at WOT and popping the fuse. Now how to figure out which one... Link to comment Share on other sites More sharing options...
pingpong Posted December 19, 2005 Share Posted December 19, 2005 My street MJ is running like poo poo. After it warms up, it runs like poo poo. you go to step on the gas to acclerate, and it bogs right down, and acts like it is going to cut off. PUsh the clutch in, and wait a sec, Idles goes back to normal, and evertything is fine. I have been working on this problem on and off for a few months, and I am about to part out this truck, cause it is pissing me off. The bad thing is all my known good parts are on my trail rig, and that is 2 hours away getting a cage built. Patrick Link to comment Share on other sites More sharing options...
mjeff87 Posted December 19, 2005 Share Posted December 19, 2005 How did you treat your Jeep tonight? I pounded the chrome beauty rings back on to the OEM steel wheels that I mounted my snow tires on, to try to cover up some of the rust on them. Lotsa cursing involved, as well as a couple of beers (at 10:30 in the morning, no less.....) Not only does it look pretty, but it goes faster now :D Jeff Link to comment Share on other sites More sharing options...
87manche Posted December 19, 2005 Author Share Posted December 19, 2005 How did you treat your Jeep tonight? I pounded the chrome beauty rings back on to the OEM steel wheels that I mounted my snow tires on, to try to cover up some of the rust on them. Lotsa cursing involved, as well as a couple of beers (at 10:30 in the morning, no less.....) Not only does it look pretty, but it goes faster now :D Jeff if you want to go really fast you need some stickers, sticker make everything go faster, I put a sticker on my water heater, and now I never run out of hot water. Link to comment Share on other sites More sharing options...
87manche Posted December 19, 2005 Author Share Posted December 19, 2005 My street MJ is running like poo poo. After it warms up, it runs like poo poo. you go to step on the gas to acclerate, and it bogs right down, and acts like it is going to cut off. PUsh the clutch in, and wait a sec, Idles goes back to normal, and evertything is fine. I have been working on this problem on and off for a few months, and I am about to part out this truck, cause it is pissing me off. The bad thing is all my known good parts are on my trail rig, and that is 2 hours away getting a cage built. Patrick EGR? And if got's an AX-15 what do you want for it? Link to comment Share on other sites More sharing options...
mjeff87 Posted December 19, 2005 Share Posted December 19, 2005 Stickers, I got stickers.....each time I buy an el cheapo muffler from Advance or Batozone, I add a sticker to the toolbox on the bed. Currently, I'm sporting a Thrush on one side, and a Dynomax on the other, plus a small American flag. They're covering up rust, too :oops: Jeff Link to comment Share on other sites More sharing options...
pingpong Posted December 19, 2005 Share Posted December 19, 2005 I have a few more things I am going to try before I resort to parting out or selling the truck. But yes it does have an AX15 :shock: as well as a Jasper motor with less then 30,000 since it was installed (PO did that), it also has a Rusty's/Pro Comp lift :D as well as a SOA D35 with 3.73, and a factory LSD :-D , Thius was my DD unitl it started having runnability problems, I really want to fix this truck, cause I miss the 21-25 miles it got to the gallon. Patrick Link to comment Share on other sites More sharing options...
mjeff87 Posted December 19, 2005 Share Posted December 19, 2005 Try disco-ing the o2 sensor. Sounds like you got a problem in closed loop operation. Jeff Link to comment Share on other sites More sharing options...
pingpong Posted December 19, 2005 Share Posted December 19, 2005 I will try that, its free and doesnt require that much work. Patrick Link to comment Share on other sites More sharing options...
