Is the Snap-on MT2500 the diagnostic tool I need for my '86 MJ 2.5L? I'm trying to figure out my mileage problems. Thinking its either a bad sensor or throttle body adjustments needed. Is there a cheaper diagnostic scanner that would work?
The MT2500 is a solid tool but it's been superceded by the Solus and a few others. I hooked up our old MT2500 up to my '87 2.5 for giggles just to see what it could read. The answer is not a whole heck of a lot.
More than anything you need the DRB connectors for whatever scanner you have. I know they made them for the MT2500 and I would think they made them for the newer tools as well. Everything I saw on the OSD you could have measured with a multimeter and/or translated into a reading with the FSM at your side. The Renix computers simply don't provide the amount of a data that you can get from a GM 12 pin ALDL or any OBD II system.
