dasbulliwagen Posted June 12, 2011 Share Posted June 12, 2011 I'm planning on buying new tires for the MJ next year, and have been looking at what I might want to get. And I noticed a size I havent really seen before or heard much about... the mentioned 32x11.50. Will this tire be an issue going on stock aluminum rims on my 87? I don't really do off roading so clearance at full flex isnt really an issue, and I have a set of WJ control arms sitting around if needed. I have a 2.5 AND 4:10 gearing, 2.8 4x4 front springs with an added isolator, and lengthened shackles on 2wd leaves out back at the moment with 235/75R15 BFG A/T's. More lift is in my future with the possibility of some trips to Uharrie, but I still wonder if there will be more issues than I want to deal with with this size? The tires I'm looking at are Yokohama Geolander A/T's in 32x11.50x15. They have the best price compared to others and a high customer satisfaction rating, and the Geolander A/T's I have on my Tucson have been performing well so far. I think the biggest part of it for me is that I want something that looks a little wider than the 31x10.50's... just for the look of it. Tell me what you think Link to comment Share on other sites More sharing options...
shawn Posted June 12, 2011 Share Posted June 12, 2011 similar set-up as me. i have the 2.5 5spd, 4:10 gears, 32" 11.5 tires and the shackles and the wj control arms. i think you are still gonna require fender trimming -even just for driving on the street. you might get away with just some minor trimming of the rear of the front flairs though- and you will have no problem with the back wheels. be prepared for a power loss on hills too. Link to comment Share on other sites More sharing options...
Motion Offroad Posted June 12, 2011 Share Posted June 12, 2011 We sell a lot of the 32x11.5 Maxxis Bighorn's. I'd say we sell as many sets of the 32's anymore as we do of the 31's. I think the reason simply is the fact that a lot of guys will run them on their factory rims and they look/feel a lot bigger than the 31's do. The only downfall I can see is finding a replacement down the road as it's an "odd" size. I'd probably recommend buying the 5th if you can swing it. Here is a local guy running them on the factory rims to give you an idea of what they look like. Link to comment Share on other sites More sharing options...
