ncm1 Posted June 5, 2011 Share Posted June 5, 2011 OK, so I found a lot of stuff searching, but never found exactly what I was looking for. I want about 4" of lift in the rear and don't want the expense of full packs. I am also never doing AAL again. I would like to go SOA but really don't want 5"-6" of lift. Is there any way to mix MJ and XJ packs to get 4"? I have some old XJ lift packs already. Link to comment Share on other sites More sharing options...
shawn Posted June 5, 2011 Share Posted June 5, 2011 i just got about 4-1/2" on an soa using chevy suburban leafs (they are flatter like xjs and the same sizes, - lenght, width, thickness). great ride! i used the chevy main +3 leafs and the mj bottom over-load. so there's that......... Link to comment Share on other sites More sharing options...
ncm1 Posted June 5, 2011 Author Share Posted June 5, 2011 So you didn't re-use the main MJ spring? Link to comment Share on other sites More sharing options...
shawn Posted June 5, 2011 Share Posted June 5, 2011 So you didn't re-use the main MJ spring? nope ------- just the 'burb main + 3. they are 56" -- perfect for your purposes. Link to comment Share on other sites More sharing options...
ncm1 Posted June 5, 2011 Author Share Posted June 5, 2011 Pretty cool. I never would have thought Burb main springs would be the same length as MJs. Link to comment Share on other sites More sharing options...
shawn Posted June 5, 2011 Share Posted June 5, 2011 3" in the front, about 4.5" in the rear. --------- 32" tires, Link to comment Share on other sites More sharing options...
ncm1 Posted June 5, 2011 Author Share Posted June 5, 2011 That's about what I'm going for right there. I just need to see if I can get there with what I have. The XJ leaf packs I have are pretty worn, the donor had a little butt sag. Anybody tried it? Link to comment Share on other sites More sharing options...
Exxon Valdez Jeep Posted June 6, 2011 Share Posted June 6, 2011 I just did this very thing today. :D My set-up is 2wd MJ main, the two middle leafs from the XJ (not the main or bottom XJ) and then the MJ over load. RuffStuff spring perches. It sits 1" lower than the front with used 4" Rough Country coils. can't tell you about ride because I don't have a driveshaft or shocks mounted yet! hope this helps! Link to comment Share on other sites More sharing options...
ncm1 Posted June 6, 2011 Author Share Posted June 6, 2011 Yes it does. Sounds like you got about 3" from your mixed pack. I'm going to give it a shot. Hope everything goes well with yours once its all back together. Link to comment Share on other sites More sharing options...
