kyleag89 Posted June 20, 2011 Share Posted June 20, 2011 Buy some 2" spacers off fleabay from blacktunaroll for $40 shipped. Then buy some chevy lowering shackles for $40 at autozone/o-riellys and be done with it. The white MJ in my sig has this combo with 31s. Link to comment Share on other sites More sharing options...
kawaboy13 Posted June 21, 2011 Author Share Posted June 21, 2011 Well how are your springs after 25 years? Thats why I was thinking ne springs. Also, I never see true 2 inch. Link to comment Share on other sites More sharing options...
kawaboy13 Posted June 21, 2011 Author Share Posted June 21, 2011 What about these and an add-a-leaf? I like the thought of more carrying capacity, but don't want it much higher in the rear if possible. Hell creek has the full length add-a-leaf. Or stick with shackles? My truck sags about all the way with about 650 pounds. http://cgi.ebay.com/ebaymotors/2-Coil-S ... 0348279301 Link to comment Share on other sites More sharing options...
kyleag89 Posted June 21, 2011 Share Posted June 21, 2011 http://cgi.ebay.com/ebaymotors/84-01-Je ... ccessories Link to comment Share on other sites More sharing options...
offroader461 Posted June 21, 2011 Share Posted June 21, 2011 when i went 3" this is what i did... 1.bought a 3" kit from JCWhitney for about $120 bucks. It came with springs and a AAL. I ran it that way for 2 years with no sag in the back even working construction with a ton of equipement in the back. My leafs are original and still to this day with the AAL gone and SOA there is no sag. At 3" you really don't need Lower Control arms or a track bar but they would be a good option. Get some spacers or some used 3" springs for the front and call it a day. For the back either do the AAL or shackles....its up to you... here was how my truck looked with the first 3" kit i put on...Ran it this way for about 2 1/2 years Here it is with 31's Link to comment Share on other sites More sharing options...
kawaboy13 Posted June 22, 2011 Author Share Posted June 22, 2011 How easy is the toe-in alignment once I've lifted my truck? Link to comment Share on other sites More sharing options...
btm24 Posted June 26, 2011 Share Posted June 26, 2011 Very very easy! Here I copied this from http://www.4x4xplor.com/alignment.html Basic Jeep Front End AlignmentAfter installing a lift on your Jeep, it is important to have your front end aligned before you drive anywhere. Failure to do so will result in severe tire wear and/or death wobble. Although not perfect, these are a few things you can do yourself to set your toe-in and re-center your steering wheel. Click on the main pic above to see a larger image What You Will Need • Ratchet • 13mm, 15mm (deep) Socket & Wrench's • Tape measure • Vice Grips or Pipe Wrench • Floor Jack (optional)* • Jack Stands (optional)* • Wheel Chocks • Someone to help you measure things *NOTE: I like to do my toe-in end alignment with my front axle sitting on jack stands. This allows the wheels to move freely making it easer to adjust. This is not a necessary step and some people will argue that you actually need to set your toe-in with your wheels on the ground. For the record, I have not had any problems with my method only and bring this information to your attention so that you can decide which method you would like to use. Setting Your Toe-In You can't see it, but your front tires are in fact not parallel to each other.... or at least they shouldn't be when pointing straight ahead. This is called the "toe-in" and if it is set correctly, the fronts of your tires should actually be pointing inward just a hair. These simple steps will help you to adjust your toe-in and can all be done in minutes. 1. Park on level ground and then with the help of a friend, measure the width between the front of your front tires and then compare that to the back of your front tires. It is important to use the exact same measuring point front and back (such as the mold seam in the middle of your tires) in order to get an accurate reading. 2. Using a 13mm socket and wrench, loosen sleeves on both ends of the tie-rod. 3. Grab the tie-rod with a pair of vice-grips or pipe wrench and rotate it a little bit at a time taking measurements along the way. Continue this process until the width in the front is about 1/16" (but no more than 1/8") closer together than the back. 4. Once your toe-in has been set, re-tighten the tie-rod sleeves and then move on to re-centering your steering wheel. Re-Centering Your Steering Wheel 1. With your tires pointing as straight as possible (leave your steering wheel rotated) and your tires on the ground, loosen the bolts on your drag link turnbuckle using a 15mm deep socket or wrench. 2. Grab the turnbuckle with your hand and rotate it a little bit at a time. Check your steering wheel periodically while doing this until it appears to be centered again. 3. Try to make sure that the bolts are pointing away from the track bar (rotate just the bolt sleeve and not the turnbuckle itself if necessary) and then tighten up the turnbuckle bolts. 4. Take your Jeep out for a test ride and determine if you need to make any other adjustments. It may take a few times to get it right but at least it is easy to do. If you just installed a 2"-3" lift, that should be about all you need to do. However, if your lift is 4" or greater, you should seriously consider purchasing a set of adjustable control arms so that you can properly set your caster. I am currently running on my OEM control arms and for now, I seem to be doing just fine. :thumbsup: Brandon Link to comment Share on other sites More sharing options...
kawaboy13 Posted July 9, 2011 Author Share Posted July 9, 2011 Buy some 2" spacers off fleabay from blacktunaroll for $40 shipped. Then buy some chevy lowering shackles for $40 at autozone/o-riellys and be done with it. The white MJ in my sig has this combo with 31s. Did you mess with brake lines or shocks? How good is the flex? Do you offroad any? Thanks! Link to comment Share on other sites More sharing options...
kawaboy13 Posted July 18, 2011 Author Share Posted July 18, 2011 Does anybody have experience with rocky road products such as lift springs and track bars? I want a lift spring with a good ride, but don't want them to sag. Motion offroad seems to have a spring that keeps a smooth ride. Rusty's are full 50 pound compression or 180 pound compression. Motion offroad increases to keep a smooth ride on smaller bumps. Any input? Link to comment Share on other sites More sharing options...
