2brandonb Posted June 1, 2011 Posted June 1, 2011 do the mechanical parts for an 88 cherokee fit painlessly for a comanche sporttruck 4wd. I have a 2.5 but want a 4.0 can you help me. there is a great deal on a neighbors cherokee and I want to get it if it will work. my truck is great just want a 6. thanks
jimoshel Posted June 1, 2011 Posted June 1, 2011 It should be a reasonably pain free swap.Having the donor sitting along side will help. It will all be R&R, no welding, cutting required.
Geonovast Posted June 1, 2011 Posted June 1, 2011 Keep in mind you can't just dump in the 6. You need to swap literally everything over from the donor, engine, tranny, all wiring, cooling stuff and accessories. You'll also need to modify your rear driveshaft.
