kyleag89 Posted May 28, 2011 Posted May 28, 2011 What size is the MJ and XJ leaf spring center pin sizes?
Eagle Posted May 28, 2011 Posted May 28, 2011 MJs are one size larger than XJs. IIRC, the XJ uses 5/16" and the MJ uses 3/8".
mvusse Posted May 28, 2011 Posted May 28, 2011 I use 3/8 pins center pins with the head ground downa bit to fit the perches, but I believe factory are 9 or 10mm (metric).
kyleag89 Posted May 28, 2011 Author Posted May 28, 2011 Thanks guys.. I'm using a XJ aal, I will have to drill the hole out larger.
