alright i did a little research and found most of what i needed to know. i pulled my cable all the way out to make sure it didnt snap somewhere between here and the tcase. it didnt. so what exactly do i do at the tcase to fix it? un-do that little clip is pretty much is far as i got from searching. and maybe something to do with the positioning of it when putting it back together. :dunno: help appreciated, id like to get this knocked out today if i can and if something is messed up theres an XJ with the exact same drivetrain as mine to snag parts off of. :cheers:
welp learning really comes from doing cause i fixed it right after my post. when i took out the gauge cluster it pulled out the speedo cable from the tcase part. so with a little re-reading of posts, i went out unscrewed the housing on the tcase and put the cable back in with fresh grease. speedo works great again! :banana:
