If your old one had all idiot lights you need to replace the temp sender and the oil sender with the ones for gauges. If your old cluster had gauges but just not the tach then just swap the clusters.
make sure that all the screaws are tight on the back of the cluster
some of mine were lose and it made my tack not work :fs1:
