1310 is the series number and there are several different u-joints within the 1310 series.
The specific Spicer part number that you want is 5-153x. And you'll need three of them.
There's one joint up by the axle, and two in the double cardan joint at the T-case. I've never replaced the cardan joints, but it's my understanding it's usually a good idea to rebuild the ball pivot assembly at the same time.
Go with a quality joint (like Spicer) over the "store-brand" one's. They'll last a lot longer. As stated the Spicer part number is 5-153x.
Also as stated if your replacing them all it's a good time to replace the socket yoke assembly. That Spicer part number is 211544X.
I got the "gold seal" ones a few weeks back from Tom Woods Custom driveshafts and
got the ones with zerk fittings in the caps. Don't remember the series number but he
will know. Cost me around $60 delivered as I recall. Rebuilding the cardan and that
spring-loaded center ball pivot was fun, especially all those tiny needle bearings. It
turned out well. I haven't installed it yet, and hope that my failure to mark everything
as it came apart will not be regrettable.
