Akula69 Posted April 24, 2011 Share Posted April 24, 2011 I have been making steady progress on Junior since I got him back from the shop. Unfortunately, I am having door alignment issues (even after searching the threads here and on Google). I have replaced both the door seals with brand new ones so I believe thats not an issue. The doors both leak at the top only, the sides and bottom are well sealed. I have moved the striker inwards (towards the seat) the the full range with no effect. I have also tried different doors as well. The hinges are not sagging and have not been re-welded. Any ideas on how to close the gap? Thanks Link to comment Share on other sites More sharing options...
Eagle Posted April 24, 2011 Share Posted April 24, 2011 Loosen the three bolts on the top hinge and two of the three on the bottom, then push the top of the door inward, then retighten. Link to comment Share on other sites More sharing options...
Cajun Posted April 25, 2011 Share Posted April 25, 2011 I agree with Eagle but it also helps to adjust the door post striker to make the door close as it should. Hinge adjustment can be tricky and it is very time consuming....Cajun Link to comment Share on other sites More sharing options...
