WN1998 Posted December 21, 2006 Posted December 21, 2006 What Axles are a direct bolt in swap for a 92 MJ Eliminator? Would a XJ 44 bolt right in?
Oizarod115 Posted December 21, 2006 Posted December 21, 2006 XJs have different rear "frame" than MJs and their leafs are mounted slightly different than ours, their spring perches won't line up to our leafs... that would be to easy. and also these trucks are SUA back axle, and XJs are SOA... so if that DID work it would net about 5-6" of lift. other than the metric-ton MJ d44, there pretty much arent any DIRECT bolt in axles... most are going to require chopping off the perches, and having new ones welded on. good news is mopar sells BEEFY perches for something like 9$ a pair. common axles to swap are XJ44s, explorer 8.8s, and MJ 44s (which if you find one is a direct bolt in)
