88MJXLS Posted April 22, 2011 Share Posted April 22, 2011 Hey guys, I have a set of power doors that I'm going to put on my Comanche (along with a list of other things) and was wondering what all is required. They came off a Cherokee, am I able to hook them straight into the harness, or will it take some modification? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 23, 2011 Share Posted April 23, 2011 Ive done this to my 87 with an 86 donor, They say there is a cross body harness for the door wiring, but Ive never seen one. I made my own harness to run across using a FSM wiring diagram as a base to build the harness. I also cut the body side connectors out of my donor so I had all the OEM connectors for the windows, locks, and mirrors. There are spots in the fuse box where you can just plug in a spade terminal for power. Its likely the fuse for them is already in there not doing anything. Good luck. Link to comment Share on other sites More sharing options...
88MJXLS Posted April 23, 2011 Author Share Posted April 23, 2011 Thanks! I might have some questions for you once I get started, lol. The door swap may be pushed back to another day, depending on how quickly I get through everything else tomorrow (fixing rockers, bedlining, VC "upgrade", new VC gasket, etc). Link to comment Share on other sites More sharing options...
