battery terminals...
what do you like? ive used the standard lead, integrated cables and clamp in, as well as solid brass or "golds". I'm using the top posts should i switch to the side terminals?
between excessive corrosion with the lead and the brittle brass seems i replace yearly and ide like better a life span.
