Backroads Posted April 13, 2011 Share Posted April 13, 2011 I just want to be sure before I pull the trigger on a new tank.... I have an 88, which should have the shorter 18gal tank. I figure if I'm doing a new tank I might as well get the 23.5 gal. Its a longbed truck, so this should bolt up fine? And I should be able to re-use my original pump and all? I read on a thread here that the front 2 straps are the same, but on the longer tank there is a third strap to the rear. I'm probably going to order new straps as well and just do it once and be done! Thoughts and opinions. Thanks! here's the tank I was looking at. Unless you guys know a cheaper outlet besides ebay...I want a place I can call and verify the item is in stock so I don't get the back-order run around http://www.autopartswarehouse.com/detai ... 70104.html Link to comment Share on other sites More sharing options...
jimoshel Posted April 13, 2011 Share Posted April 13, 2011 You're OK on the tank, pump and straps. EBay is about as good as your going to get. However be sure and check the prices. I've as much as a $100 difference between vendors. Also check on shipping. Link to comment Share on other sites More sharing options...
Backroads Posted April 13, 2011 Author Share Posted April 13, 2011 Thanks for the quick reply. That link I posted seems like the best deal for me. $147 shipped and its galvanized. Link to comment Share on other sites More sharing options...
Backroads Posted April 13, 2011 Author Share Posted April 13, 2011 after reading reviews of that place I went elsewhere! but ordered up a 23.5 gal tank, straps, filler the whole 9. Link to comment Share on other sites More sharing options...
veritas4156 Posted April 14, 2011 Share Posted April 14, 2011 surprisingly my 20 year old filler was fine when i swapped my tank. Seriously looked and felt like brand new rubber. Link to comment Share on other sites More sharing options...
