boosst Posted April 12, 2011 Share Posted April 12, 2011 My sway bar links were making a ton of noise. I tried to tighten them but the stud coming from the top of the links just spins. Are these broke? Is there a way to hold it still to tighten that nut? Link to comment Share on other sites More sharing options...
64 Cheyenne Posted April 12, 2011 Share Posted April 12, 2011 Nope, it's broke. Don't see how, no other esplanation. Link to comment Share on other sites More sharing options...
boosst Posted April 15, 2011 Author Share Posted April 15, 2011 If my links are both broke I guess I need replacements. I have a 3" lift...which ones do I get? Will stock ones work? Link to comment Share on other sites More sharing options...
64 Cheyenne Posted April 16, 2011 Share Posted April 16, 2011 Any of the aftermarket discos will work. Depending on the money you want to spend and how much you wheel your truck, stock might work for a while...Problem is they will start to bend and eventually break like you have now. Best bet, buy some for a 4" lift and be done, or if you can weld, weld 2 sets together to make a longer set. Longer welded ones won't be discos, but as I said depends on how you wheel your truck. Gone over many times before: no links= :wall: or worse XXX Feelin lucky? Link to comment Share on other sites More sharing options...
05mxdiesel Posted April 17, 2011 Share Posted April 17, 2011 Get 92+ Cherokee links, they are a little over an inch longer than stock comanche links, works perfect with 3" lift. Link to comment Share on other sites More sharing options...
