1sickmj Posted April 5, 2011 Share Posted April 5, 2011 i want full size axles, i'd like to keep my coil springs and obviously the upper and lower control arms, what are my options? as in use axles out of a 2nd gen dodge? i've seen cherokee's with full float 1 ton axles but what are they using? or is it a regular axle with the mounts and such welded on to older axles? i've never been able to take a good look at how they are set up, just that they are 8 bolt and the whole tire sticks out the side. i'm running 36's but i doubt the 30/35 combo will last long :rotfl2: Link to comment Share on other sites More sharing options...
mnkyboy Posted April 5, 2011 Share Posted April 5, 2011 Usually you would add the mounts to an older style axle. Link to comment Share on other sites More sharing options...
