A look at the evolution of the MJ Engine
beepbeepmyredjeep
I've compiled some interesting specifications for the various engines used in the Comanche.
Here's the history of the Comanche Engine...
1986:
Two gasoline engines offered, Inline-4 and V-6.
Very little historical information found in news articles about the 1986 Turbo-Diesel, but it is mentioned.
4 cylinder 250 cubic inch (2.5 L)
117 hp @ 5,000 rpm
135 ft-lb torque @ 3,500 rpm
24/27 mpg
6 cylinder 2.8L (V6)
150 ft/lb of torque @ ??? RPM
17/22 mpg
1987-1990:
The I-4 remains the same, but gains hp and torque due to a larger air cleaner.
The V6 is replaced with a 4.0L Inline-6.
So, could 1986 I-4 owners gain hp and torque by swapping in the 1987 air cleaner?
4 cylinder 2.5L
121 hp @ 5,000 rpm
141 ft/lb of torque @ 3,500 rpm
6 cylinder 4.0L
173 hp @ 4,500 rpm (NOTE: A 1991 article states that the 1990 engine had 177 hp. It is believed this was a misprint)
220 ft/lb of torque @ 2,500 rpm
1991-1992:
Both I-4 and I-6 receive upgrades.
4 Cylinder 2.5L
126 hp @ 5250 RPM
148 ft/lb torque @ 3000 RPM
Multi-point fuel injection system (previous years were throttle-body fuel injection).
6 Cylinder 4.0L
190 hp @ 4750 RPM
225 ft/lb torque @ 4000 RPM
You say, aside from the air cleaner that there are no differences between the 86 and 87 4 cylinders. I thought the 86 was carbureted?
no. the 84-85 were carbureted...so that was only in the cherokee and cherokee wagoneer.
