duradiesel Posted April 1, 2011 Posted April 1, 2011 Where can I get the tube that runs from the MAP sensor to the throttle body? Only place i've read was at the dealership. I realy can't go to the dealership in Italy. So if anyone knows a place online that i can get it at, the info would be greatly appreciated.
MJRemi Posted April 1, 2011 Posted April 1, 2011 I'm at work so I can't measure the tube diameter but it's just a soft, rubber hose that fits onto the MAP nipple. I would think auto parts or hardware stores will carry something that can be used for your purpose. This is a vacuum set from Rock Auto http://www.rockauto.com/catalog/moreinfo.php?pk=586584
JeffN Posted April 1, 2011 Posted April 1, 2011 It's actually a molded hard plastic tube that runs from the throttle body to the map sensor. The end that goes into the throttle body is hard plastic with a small rubber hose that hooks up to the map sensor. I think i may have a good one, if i do i am willing to ship it wherever you are.
duradiesel Posted April 3, 2011 Author Posted April 3, 2011 That would be great. If you have one i'll send you my address. Thanks
