Hesitating when accelerating from a stop
My MJ has had this issue for several months now, but is now happening often enough to start me worrying. Occasionally when I take off from a stop, with light throttle the engine will cut out momentarily. Since its a stick it causes the whole truck to jerk, which is annoying.
I haven't done any actual diagnosis as of yet, it's a 4.0 renix, open filter, 2.5 exhaust with no cat/flowmaster 40. EGR has been unhooked, higher end borg warner cap, rotor, and wires (probably 25,000 miles on these), PO said he replaced O2 sensor recently when I bought it (about 35,000 mile since), fuel filter was replaced probably 7,000 miles ago. Champion copper plugs, standard heat range (not sure if I should run a cooler range with no EGR). There have been no recent changes to the truck, besides the axle swap (in December).
My guess is a fuel pump, but I'm interested in you guys' $.02
Also the ballast resistor is newer, but I think a slightly higher resistance than stock. Like 0.2 Ohms higher
Put an ohm meter on your TPS to. It may have a dead spot. My 2.5 was like that. Under real light throttle like 5-10% it had a dead spot. Computer didnt know what to do.
I may have to try that, I'll also do a visual on the O2 sensor. I wonder if jeep will still replace it since the recall was never done.
