mjdavis31 Posted March 26, 2011 Share Posted March 26, 2011 new to the site looking for a little help i have a 88' sport truck that started life as a 2.5 4 speed 2wd. i first put a front axle under it and a 5 speed and np 207 that i picked up of CL. then lifted it did an 8.8 swap. just recently i picked up a running 91' 4.0 speed with a busted up rearend 4 200 bux so i pulled my motor trans and t-case to make so room. then tried to bolt the engine in with the original frame mounts no worky of coarse the 91 already went to the crusher. so i went to the bone yard and picked up so mounts off the first 91+ 4.0 i found with the engine out bolted then in and the engine bolted in but looked a little to far back then i installed the trans and it seems to be sitting 2-3 inches to far back i cannot bolt up the trans x-member do i have the wrong mounts? i don't know. :mad: sorry for the long story but i figure the more you know the easer it will be to help thanks. Link to comment Share on other sites More sharing options...
cody4359 Posted March 26, 2011 Share Posted March 26, 2011 i just put a 96 4.0 in my 89 mj, i thought the same thing but i was trying to put the 4.0 mounts 2 bolts back further than they were supose to go. once i had the mounts in the right spot it fell right in. did you grab the tranny x member with the tcase you bought? i had to chase/tap the holes with a 10x1.50 tap. you also said you grabbed the motor but nothing about the harness? 2.5, 4.0 harnesses are different. hope that helped a little edit: this is the diy forum, next time try posting in the tech :thumbsup: Link to comment Share on other sites More sharing options...
mjdavis31 Posted March 27, 2011 Author Share Posted March 27, 2011 yeah i got the x-member and its in the furthest holes back. i got the 4.0 harness i had to hook a come alog to the front for the engine to get the x-member bolted up it seems like the engine frame mounts sit to far back still???? Link to comment Share on other sites More sharing options...
