veritas4156 Posted March 19, 2011 Share Posted March 19, 2011 A few weeks ago I was driving along and my right rear made a thump like I hit a pothole. I didn't hit anything, had no load in the bed, etc. Over these past couple of weeks I've been getting some weird driveline vibes, which I assumed must be a u-joint on its way out. My tires started wearing unevenly and quickly, which I couldn't figure out. Today I was standing behind my truck smoking a cig and noticed that the driver side tire sits inside the wheel well about 1/2 inch and the passenger side sits outside the wheel well about a 1/2 inch. Crap. So now my rear axle is off center. Looked for reasons and my passenger side shackle is just plain crooked. Pics follow. What the hell did I do and will replacing the shackles fix it? Link to comment Share on other sites More sharing options...
kyleag89 Posted March 19, 2011 Share Posted March 19, 2011 I have the same problem with my XJ. I think it could be the centering pin for the leaves snapped. Link to comment Share on other sites More sharing options...
veritas4156 Posted March 19, 2011 Author Share Posted March 19, 2011 Hmm.... I'll have to get under it in the morning and check it out. Hopefully my buddy is gonna be around so i can just throw it on his lift. Link to comment Share on other sites More sharing options...
kyleag89 Posted March 19, 2011 Share Posted March 19, 2011 I don't think you will be able to tell if it is broken unless you unbolt the axle from the leaves. Link to comment Share on other sites More sharing options...
Automan2164 Posted March 19, 2011 Share Posted March 19, 2011 Looks like the whole assembly is cocked. How do the bushings look in the springs and shackles? U-bolts tight? Any evidence of bent items? Rob Link to comment Share on other sites More sharing options...
dave92cherokee Posted March 19, 2011 Share Posted March 19, 2011 From the pics it looks like either the bushings in the shackles are shot or the bushings in the back of the leaves are shot, or maybe both. I'd pull the shackle off the passenger side first as it looks like the worst condition and inspect both bushings. Link to comment Share on other sites More sharing options...
kyleag89 Posted March 19, 2011 Share Posted March 19, 2011 When I removed my shackles the bolt was seized into the metal sleeve in the bushing, so I had to cut them out. Link to comment Share on other sites More sharing options...
flint54 Posted March 19, 2011 Share Posted March 19, 2011 I had to do the same. Sawzall metal blades - several of them. It seems unlikely that the axle would have shifted laterally even if the spring centering pin failed, because of the clamping force of the torqued U-bolts. To confirm, I suggest measuring along the top of the axle tube from outer U-bolt to break backing plate to confirm same on both sides. I suggest also measuring from the front leaf spring bushing back to the axle tube and see if same on both sides. These should tell you if axle shifted relative to leaf springs. I also think it's most likely to be worn out spring and/or shackle bushings. Contact me offline if you're interested in a set of new OEM spring bushings. JKS makes really stout shackles that have grease fittings. That way, twenty five years from now, the next owner won't have to cut the bolts. Link to comment Share on other sites More sharing options...
veritas4156 Posted March 21, 2011 Author Share Posted March 21, 2011 I haven't really had a chance to take it all apart yet because of my current job search and having to swap the tranny on my father's commuter car. I did get a chance to peek underneath the truck and I still can't see anything worn out or broken other than the shackle being bent on the passenger side. The bushings seem good (as far as I could tell by looking and prodding). I have next weekend off so I"ll take it apart then and let you guys know. Anyone wanna hire a recent Binghamton University MBA grad with very little experience? Link to comment Share on other sites More sharing options...
