brian Posted March 18, 2011 Posted March 18, 2011 Where is the sending unit for the water temp guage and also for the oil press. gauge? Neither of mine are working but I don't know whether it's the guage or the sending unit or disconnected wire/hose?? :dunno:
JeffN Posted March 18, 2011 Posted March 18, 2011 Renix era the temp gauge sending unit is on the back top of the head on the drivers side oil sending unit is screwed into the oil filter housing.
brian Posted March 18, 2011 Author Posted March 18, 2011 so before I go climbing around with a shop light...am I looking for a wire connection on the oilsending unit or a hose? :oops:
comanche12 Posted March 18, 2011 Posted March 18, 2011 wait- is your cluster guage is renix gauge with idiot lights or it swapped renix gauge with tachometer? btw- look for wire connect for oil pressure :thumbsup:
brian Posted March 18, 2011 Author Posted March 18, 2011 Don't know what renix means sorry no idiot lights actual dials and needles. yes it has a tach this isan '89
Eagle Posted March 18, 2011 Posted March 18, 2011 Renix is shorthand for the RENault-BendIX injection/ignition system used in the Comanche from 1987 through 1990. For the Comanche, it doesn't matter what year you have, the temp sender for the gauge is at the very back corner of the head, on the driver's side, and the oil pressure sender is screwed into the oil filter mounting adapter. Each will have a single wire coming off the end.
comanche12 Posted March 19, 2011 Posted March 19, 2011 Renix is shorthand for the RENault-BendIX injection/ignition system used in the Comanche from 1987 through 1990. For the Comanche, it doesn't matter what year you have, the temp sender for the gauge is at the very back corner of the head, on the driver's side, and the oil pressure sender is screwed into the oil filter mounting adapter. Each will have a single wire coming off the end. :agree:
brian Posted March 19, 2011 Author Posted March 19, 2011 thanks lots. I'll crawl in there and see what's up
comanche12 Posted March 19, 2011 Posted March 19, 2011 thanks lots. I'll crawl in there and see what's up welcome and no need crawl, all you need is climb :wrench:
