H3RESQ Posted March 17, 2011 Share Posted March 17, 2011 Searched a bit. Looking for a good thread on 97+ dash conversion. I'm getting a 2000 interior including column with key and keyfob for power doors. Looking for what I need to pull from vehicle to make everything work. Please help me with a good DIY thread, can't seem to find a good one. Thanks, Jason Link to comment Share on other sites More sharing options...
87Warrior Posted March 17, 2011 Share Posted March 17, 2011 You really need the whole rig. Checkout Ryan's build (1990 Rebirth), JeepCo's (utilitarian build), and shelbyluv's (onyx). You can also follow mine, but its not running. Short list of what you will need: Heater and AC box Aluminum dash sub-frame Interior wiring harness Interior fuse panel Engine harness with PDC PCM All engine sensors Fuel pump and sender Dome light (FOB receiver) and wiring back to main harness AW4 brain if an auto Being a 2000 it will have a cam sensor in place of the dizzy and coil packs. You will also need: Coil rail Camshaft position sensor Head Intake and exhaust manifold Throttle body Its also a good idea to get the whole rig for mrsurements sake to get holes cut in the firewall correctly since not much is the same shape or in the same location. That an buying everything separately would cost a fortune and would take forever to obtain the right parts. Then it would be a guessing game to get it put together. Link to comment Share on other sites More sharing options...
H3RESQ Posted March 17, 2011 Author Share Posted March 17, 2011 THANKS! Glad I asked before picking up the stuff. Link to comment Share on other sites More sharing options...
