sinkrun Posted March 15, 2011 Posted March 15, 2011 I need and only want the 97up style door checks must be for the front either side of a XJ Cherokee only Grands are different. Really only need one but would buy 2 must work smooth also need the bracket it bolts to as mine are ovaled out (rear brackets are the same and often in better shape)
cody4359 Posted March 23, 2011 Posted March 23, 2011 maybe stealership?? i done with school fri and a month ago or 2 i found 2 +97 xjs in the jy. if i have time ill check then. hey, if you go to do a 97+ door swap you should grab the door check.... just for future reference :D
