Anybody ever swapped one in? It was just a thought seeing as how my gas tank is rather rusty and plastic tends not to bend like metal. And it would center up the weight.
Thanks for any tech tips or pics! Pics would be GREATLY appreciated.
Forget about the XJ tank. Wrong dimensions to fit. It has been looked at by others and always abandoned.
Buy a new gas tank for your truck on ebay as on the topic above.
The stock spare tire is 9.5 inches high which is much shorter than a Cherokee gas tank.
I looked at it for my 91 long bed. From memory, you will need a tank about 30 inches square and 9 or 10 inches high.
Ford F150 gas tanks are close with 18 or 19 gallons. Even at that you will loose some ground clearance and have just your bumper between your gas tank and some other car or truck that can run into you. I have a trailer hitch bolted to my frame, so have that in addition to my stock bumper.
Best solution is to replace your stock tank with another stock tank. You get them on Ebay for less than $100
i have seen builds where the owner installs an xj tank in the box, right behind the cab. but you need to cut a big hole in your box :ack:
