baldntatted Posted March 1, 2011 Posted March 1, 2011 If i put a 6.5 lift on my mj and 33's do i need to change the back axle? i am a rookie at MJ's
Fire4755 Posted March 1, 2011 Posted March 1, 2011 depends which axle and what gearing but ether way that much lift will need alot more then just a rear axle.
mnkyboy Posted March 1, 2011 Posted March 1, 2011 I have a 6.5" lift and 33x12.50s on the stock axle with no issues. unless you plan to do serious wheeling your probably OK,your issue is gonna be gears.
baldntatted Posted March 2, 2011 Author Posted March 2, 2011 no don't plan on wheeling. ill use the truck for deer season in and out of the woods mainly getting my harvest out of the woods.
mnkyboy Posted March 2, 2011 Posted March 2, 2011 Do you know what axle you have now? If its a d35 I would find a d35 from a 4cyl 5spd and swap it in they came with 4.10 gears
