Comanchero87 Posted February 26, 2011 Share Posted February 26, 2011 Tried to check the fluid in the ax15 today. Fill plug stuck. So I've read you can add fluid through the shift plate. How do you guys go about removing those 4bolts? Thanks in advance for the replies. Link to comment Share on other sites More sharing options...
Automan2164 Posted February 26, 2011 Share Posted February 26, 2011 You can get them all from the top fairly easily. Take off the console, and three inner boot. Once your there, you should be able to see a couple, and those you can usually get with a socket and extension. The others you'll have to use a wrench and patience as they usually take awhile to get out. Rob L. Link to comment Share on other sites More sharing options...
mjeff87 Posted February 26, 2011 Share Posted February 26, 2011 you can just pull the shifter, no need to remove the entire plate. Press the metal "cup" surronding it down and rotate it counterclockwise, and it will pop up. Pull the shifter upward and it, the cup and the spring will come out of the shift tower. Jeff Link to comment Share on other sites More sharing options...
91coMANche Posted February 26, 2011 Share Posted February 26, 2011 How will you measure quantity? Did it leak? Link to comment Share on other sites More sharing options...
kro10000 Posted February 26, 2011 Share Posted February 26, 2011 Have you tried heating up the plug with a torch? Should free up a stuck plug Link to comment Share on other sites More sharing options...
