JEEPER1 Posted February 15, 2011 Posted February 15, 2011 wich do you guys suggest? i did a sping over on my yj and really liked it becuase i still had the soft ride from the factory leaf springs, but this will be my first time lifting a MJ so wanted to know what you guys think is the best route? or the pros and cons. thanks Eric
btm24 Posted February 15, 2011 Posted February 15, 2011 How much lift are you looking for? what will you be using it for? Brandon
JEEPER1 Posted February 15, 2011 Author Posted February 15, 2011 about 5.5 in, and use will be hunting truck / trail truck .
btm24 Posted February 15, 2011 Posted February 15, 2011 Ok well i think that with a SOA you get some where around 6". so if you going to go for 5.5 why not go to 6? lol I think that will be your better bet. Lift springs also cost alot and it may be cheeper to go with a SOA. what kit were you thinking of? or were you going to make your own? Brandon
MancheKid86 Posted February 15, 2011 Posted February 15, 2011 Ok well i think that with a SOA you get some where around 6". so if you going to go for 5.5 why not go to 6? lol I think that will be your better bet. Lift springs also cost alot and it may be cheeper to go with a SOA. what kit were you thinking of? or were you going to make your own? Brandon you will get any where from 4.5-6 inch of lift out of the factory springs, it all depends on the quality left in leaf's ie. the sag
