btm24 Posted February 6, 2011 Posted February 6, 2011 Will a 4x4 shifter like, this work from a HO 4.0 going on to a renix 4.0? Every thing else is the same its off of a 231 t-case, and aw4 tran. Brandon
Eagle Posted February 6, 2011 Posted February 6, 2011 The engine has nothing to do with it. The only difference in the transfer case shifters is the length of the connecting rod between the shift handle and the bellcrank lever on the t-case. That's a function of the transmission length.
btm24 Posted February 6, 2011 Author Posted February 6, 2011 Ok well I was not sure if there were any changes between in transmission. Thanks Brandon
