I have a 231 shifter/shift gate with linkage and the ultra-mini console (only around shifter, was a column shift truck) sitting on the barn floor. Was removed 2 weeks ago to not be damaged by media blasting.
Should be able to ship for $5-10 depending how the linkage folds up. Will sell for $20 shipped if you replace those RC wheel spacers, or $30 shipped on Monday :waving:
I would if I could get that 100 bucks i spent on them back... can you post up or send me a few pic's? Thanks so much this will be a big help
Brandon
:fs1: I can get better pictures tomorrow in the sunlight. Only one bulb in the garage is working.
It's a little greasy, but worked prefect in my truck. There is a scratch on the clear plastic over the "4-High".
Ok that looks great. Get me a pic of the scratch but I'm sure this is what I want. Do you know what other linkage Ill need to hook it up? Also why did you take it out of your truck? Thanks!
Brandon
I do not need this linkage or shift gate because I will be using the stuff from my XJ donor and 242, build is in my signature.
What is pictured is the 231 shift gate/shifter assembly, the body mount, and the mount that bolts to the t-case and transmission. As long as your t-case has a 3" linkage mount pointing downward near the front yoke, this stuff should get you bolted up. If you picked up your tranny and t-case from an XJ it probably has part of the linkage attached. The friction adjustment bolt is missing, but its just a 13mm that you torque down to align the shift leaver.
I will take a picture of the scratch in the morning. If your truck is a floor shift truck, the ultra-mini console won't do you much good. The parts did come off my HO 92, with AW4 and 231. I have no clue if there are any differences in the bracketry between autos and 5spds, or renix and HO.
Ok well mine has the shifter on the tree so This is what I needed. Ill ask about if there was a difference between the renix. Ill ask today. Thanks
Brandon
Yeah, its dirty. Been sitting in a dirt barn. The light scratch is the only damage to it. (it may disappear once cleaned up)
