btm24 Posted February 4, 2011 Share Posted February 4, 2011 I need a 4x4 shifter and console. If you have linkage that would be great also. Thanks Brandon Link to comment Share on other sites More sharing options...
87Warrior Posted February 4, 2011 Share Posted February 4, 2011 I have a 231 shifter/shift gate with linkage and the ultra-mini console (only around shifter, was a column shift truck) sitting on the barn floor. Was removed 2 weeks ago to not be damaged by media blasting. Should be able to ship for $5-10 depending how the linkage folds up. Will sell for $20 shipped if you replace those RC wheel spacers, or $30 shipped on Monday :waving: Link to comment Share on other sites More sharing options...
btm24 Posted February 5, 2011 Author Share Posted February 5, 2011 I would if I could get that 100 bucks i spent on them back... can you post up or send me a few pic's? Thanks so much this will be a big help Brandon Link to comment Share on other sites More sharing options...
87Warrior Posted February 5, 2011 Share Posted February 5, 2011 Sure thing. I will get a few pics of the assembly tomorrow and post them up. Link to comment Share on other sites More sharing options...
87Warrior Posted February 6, 2011 Share Posted February 6, 2011 :fs1: I can get better pictures tomorrow in the sunlight. Only one bulb in the garage is working. It's a little greasy, but worked prefect in my truck. There is a scratch on the clear plastic over the "4-High". Link to comment Share on other sites More sharing options...
btm24 Posted February 6, 2011 Author Share Posted February 6, 2011 Ok that looks great. Get me a pic of the scratch but I'm sure this is what I want. Do you know what other linkage Ill need to hook it up? Also why did you take it out of your truck? Thanks! Brandon Link to comment Share on other sites More sharing options...
87Warrior Posted February 6, 2011 Share Posted February 6, 2011 I do not need this linkage or shift gate because I will be using the stuff from my XJ donor and 242, build is in my signature. What is pictured is the 231 shift gate/shifter assembly, the body mount, and the mount that bolts to the t-case and transmission. As long as your t-case has a 3" linkage mount pointing downward near the front yoke, this stuff should get you bolted up. If you picked up your tranny and t-case from an XJ it probably has part of the linkage attached. The friction adjustment bolt is missing, but its just a 13mm that you torque down to align the shift leaver. I will take a picture of the scratch in the morning. If your truck is a floor shift truck, the ultra-mini console won't do you much good. The parts did come off my HO 92, with AW4 and 231. I have no clue if there are any differences in the bracketry between autos and 5spds, or renix and HO. Link to comment Share on other sites More sharing options...
btm24 Posted February 6, 2011 Author Share Posted February 6, 2011 Ok well mine has the shifter on the tree so This is what I needed. Ill ask about if there was a difference between the renix. Ill ask today. Thanks Brandon Link to comment Share on other sites More sharing options...
87Warrior Posted February 7, 2011 Share Posted February 7, 2011 Ok that looks great. Get me a pic of the scratch but I'm sure this is what I want. Yeah, its dirty. Been sitting in a dirt barn. The light scratch is the only damage to it. (it may disappear once cleaned up) Link to comment Share on other sites More sharing options...
btm24 Posted February 19, 2011 Author Share Posted February 19, 2011 Got it thanks! Brandon Link to comment Share on other sites More sharing options...
