Trailer wiring
Ok here goes, I am looking for a good writeup (assuming there is one) on installing trailier wiring on the Comanche. Can anyone point me there?
So far I have found the following for wire colors, I suppose it's a start.
Ground:
Comanche harness = Black
four wire flat trailer wiring = White
Position on plug 159 (behind left taillight) Not included in plug, must ground to body. (and clean up that ground while I'm at it)
Common (running lights):
Comanche harness = Dark Blue
four wire flat trailer wiring = Brown
Position on plug 159 (behind left taillight) pin A
Right turn signal / brake light:
Comanche harness = Brown
four wire flat trailer wiring = Green
Position on plug 159 (behind left taillight) pin B
Left turn signal / brake light:
Comanche harness = Grey/tr *or* grey/black (depending on which side of the connector behind the left taillight we are talking about)
Position on plug 159 (behind left taillight) pin C
Here is an image of the plug, for reference.
Yes, it looks like I am more writing a guide than asking for one. I am just looking for input before I start tinkering with my wiring harness. anyone have any advice?
