btm24 Posted January 25, 2011 Share Posted January 25, 2011 Would a B&M shifter work as a 4x4 shifter? thanks Brandon Link to comment Share on other sites More sharing options...
jimoshel Posted January 26, 2011 Share Posted January 26, 2011 Go to the B&M web site and check their listing. You could probably modify one and make it fit but why? :dunno: Link to comment Share on other sites More sharing options...
alleydog Posted January 26, 2011 Share Posted January 26, 2011 In theory it would. But,an important part of the stock shifter is the gate, and the B&M shifter wouldn't have the gates in the right place. Link to comment Share on other sites More sharing options...
btm24 Posted January 26, 2011 Author Share Posted January 26, 2011 Whats a "gate"? And because I can't find a stock one for under 40 bucks so I thought a B&M one would look really nice and work well also. Brandon Link to comment Share on other sites More sharing options...
alleydog Posted January 26, 2011 Share Posted January 26, 2011 The gate is the notch that the shift lever stops at when you pull the lever back to 4 hi. then you have to move it over to continue back to 4 low. Link to comment Share on other sites More sharing options...
btm24 Posted January 26, 2011 Author Share Posted January 26, 2011 Ok well then I guess ill have to stick with a stock one :( thank you for the info. Brandon Link to comment Share on other sites More sharing options...
