Hubbell Posted January 23, 2011 Posted January 23, 2011 first off the mj is an 87, 2.5, ax4, 2wd problem started all of the sudden. it will start but won't stay running, i can feather the pedal to keep it going but let off the gas and it stalls out. I just don't know where to start in the search function but this 2.5 is new to me and i need some CC knowledge, of course this started when I'm in the middle of moving and had the trailer loaded already. :fs1: so where do i start
Hubbell Posted January 23, 2011 Author Posted January 23, 2011 ok on a 4.0 i can do that but on the 2.5 its TBI....i feel stupid but how?
airspeed Posted January 23, 2011 Posted January 23, 2011 In my manual they show a special TEE fitting with a pressure gauge that goes between the throttle body and the input fuel line. I think the pressure should be ~14psi.
Hubbell Posted January 23, 2011 Author Posted January 23, 2011 thank you airspeed i have been reading more info for the culprit of my problem and making a list of things to check in the morning. any other ideas that i can add to the list?
Hubbell Posted January 23, 2011 Author Posted January 23, 2011 also on the 2.5 where is the map sensor located?
rnobles Posted January 24, 2011 Posted January 24, 2011 MAP sensor is on the firewall almost directly behind the throttle body, kinda between the throttle body and valve cover. (at least thats where its at on my 86)
Hubbell Posted April 15, 2011 Author Posted April 15, 2011 its only been months but finally had a chance to work on my problem. ended up being the fuel pump, not sure if the pump was actually bad but the rubber hose in the tank was gone so probably could have just changed that one dollar part and it would have, maybe, worked. oh well. thanks for the input, alot of posts are gone because of the Houdini sunday thing, but thanks just the same. Chris
