wannabeMJ Posted January 22, 2011 Posted January 22, 2011 well i was testing the truck today and found out that the starter gets engage when I put the key to electric and it stays on once the truck is started any ideas on what can cause that :dunno: ignition switch is new wire to the starter is new because i don't wanna put a new starter and just burn it cause its doing the same thing edit: its for a cherokee 1990 4.0L
vaquaro Posted January 22, 2011 Posted January 22, 2011 The ignition switch is on drivers side of the steering column down near the firewall and actuated by a rod from the key lock on the passenger side just behind the steering wheel . If you replaced the key switch it's very easy to jar the cog-gear (clocked wrong) out of sync with the toothed track that pulls the rod to the "ignition switch " on the lower column. WHEW.....That switch (below ) can be adjusted by loosening 2 small bolts and moving it up/down slightly to get your key switch back in sync . Or pull the switch and re-align the gear-cog and track . Try a search here for illustrated tear downs in the Tech section :thumbsup:
kyleag89 Posted January 22, 2011 Posted January 22, 2011 Take the switch back out click it all the way towards the wheel to the ACC position. Then install it hold the key all the way back and tighten the bolt and nut holding the switch down. This ensures you have it in the correct position.
wannabeMJ Posted January 22, 2011 Author Posted January 22, 2011 it does the same if I have the switch in my hand and manualy operate it so its not the position of the rod on the ignition switch
JeffN Posted January 22, 2011 Posted January 22, 2011 sounds like the clip holding the bendix from smacking the nose of the starter has broke causing the bendix to go too deep into the flywheel jamming into the flywheel pull the starter and there should be a round "hat" with a round wire clip inside it holding it into a groove in the starter armature.
wannabeMJ Posted January 24, 2011 Author Posted January 24, 2011 the clip look fine I took everything apart and actuated the bendix manualy everything move normaly and nothing is broken it was if the starter is not shutting off once the truck is started electricaly speaking the starter take the power from the battery but is activated trough the relay I will check the relay today and replace it with a new one
wannabeMJ Posted January 24, 2011 Author Posted January 24, 2011 well the starter is fried so Ill try to rebuild it unless it's seaze if not ill order a set of brushes on ebay to do it if not it will be time for a trip at the JY :thumbsup:
